Brick wall on E6400
11 Jan 2008
I seem to have hit a wall at 3.2g, heat isn't the prob as it is aroud 50ish under load.
My rig is:
E6400
Gigabyte GA-P35-DS3L
Geil ddr2 800 ultra low latency
arctic pro 7
Anyone with similar system have a good set of settings?
Thx
Chris
Set the ram to 1:1 multi
up vcore a notch or two and retry
if that fails try upping the mch(chipset) voltage and vfsb a notch.
I think you just need more vcore. I know all chips are different but for 3.2 i need 1.375 bios which is 1.328 after vdroop. If you think you've hit a wall for another reason then try putting 1.4 or a voltage that is more than enough, test it at that and then turn the voltage down until it becomes unstable. Your temps are good enough that you an afford to turn up the vcore quite a lot.
