Bridge 2 wirless networks?
4 Jan 2004
¯\_(ツ)_/¯
Ok, I've got 2 wireless networks that I need to bridge. What is the best way of doing this?
Could I use an old computer with a linux distro and 2 wifi cards? It should be possible with this setup shouldn't it?
Or what about a computer with 1 wi fi card, and a normal RJ45 cable to a wifi router? I guess it should also be possible with this setup, but i'm not so sure if it would work. I've got a spare linksys wag54g router doing nothing right now.
I don't believe Linux will be able to do this. I was thinking about bridging my Ethernet and wireless using a Linux box, but I found almost no information on it, and what I did find suggested that Linux has very poor support for it.
Before that I used to use Windows 2003's network bridge to do it, but the Wireless kept failing. I am not sure if that is down to Windows, the drivers or the hardware, but I wouldn't recommend it.
Best bet would be some kind of hardware/router solution, but I am not sure how you would do that.
