Bridge mode router
I need a good one that can match what I have above that one might slow things down will it not
Your modem will only affect your incoming line, which you haven't mentioned your line speed.
What package are you on? The HG612 will work for standard FTTC as it'll do up-to around 80Mbps
Do you have a large box on the wall with Openreach written on it? If you have G.fast then you're in for a painful time trying to get a modem. Post a photo.
But you have the BT Hub already that has been sent to use with the service? Take a picture of the rear of that.
What happens when you put your address in this checker - http://dslchecker.bt.com/? Click 'Address Checker', then Proceed, then enter just your postcode and click Submit, then pick your house from the list.
i dont have that until the 29th but it is the BT hub 2 they are sending me
Does this help https://imgur.com/HwZ6ABG
I am not with BT yet so this is with who I am with now can redo this on the 30th if you need
