British Gas serviced my boiler , now have no hot water!
24 Aug 2006
Pilot light is on, boiler comes on for 1 minute then goes off leaving just the pilot light on.
Utter rubbish from British Gas
If I based the manner of handling this on many of the customers I deal with, the answer is to call them, email them, go on twitter and complain that they didn't fix it a week ago before you told them of any issue, then call again and scream at the call handler and threaten them with legal action because no hot water has cost you millions in lost business..
Or do it the GD way.. poop through their letterbox..
It could just be that they messed up somewhere and the cut off is just a safety system kicking in like it does on condenser boilers where if the pipe leading to the drain/outside is blocked and the water level is up to the cap on top of the pipe then the boiler will fire up bit will cut off in short order (this is just an example from my experience, but the issue might be from a different safety system).
facebook them, i know, i know facebook grrrrrr, but companies seem to be way more responsive when they get bad facebook press. I did this with Ikea and they had my problem resolved in an hour.
I've had a contract for years and never been hassled about buying any extras. Maybe it's down to the individual engineer who visits ? They might be on commission or something
Have you tried opening the water input valve?
I had a technician come to check our boiler once, and he left the input valve turned off hence, no hot water.
Probably best to let BG sort it out if they caused the situation and you're not too clued up on boilers.
My experience with BG was poor. Had a BG engineer round to do a free check on my boiler on buying my house and he said it was all OK apart for the way it was connected to the main water supply. Why he said that I don't know as on having my boiler serviced I had the system checked and it was as good as it could get! bizarre.
Same here. The engineers don't try and sell stuff beyond giving me a leaflet in with the annual service paperwork but I do get a load of follow up sales calls the month after.
OMG WHY AREN'T BRITISH GAS TELEPATHIC!?! THEY ACTUALLY EXPECT ME TO CONTACT THEM BEFORE THEY'LL FIX SOMETHING, IT'S LIKE LIVING IN THE STONE AGE1111!!!1!1!!!
Mistakes happen, no one is perfect, call them get it sorted problem solved.
is this the stage of things now, immediately go onto a board and moan about something instead of just callling up the guys and telling them to coe and sort what they broke?
Pretty much, although it pays to go into twitter first or the like.
No company wants their public facing wall filled with complaints..
