right i have a problem on my new pc with my broad band, it only happens while gaming an works fine on my other pc, basicaly while playing bf2/2142 i get lag which lasts 1/2seconds maybe more, my ping is constantly changing which makes it impossible to play.
at first i thought it might have been the usb ports but having tried them all i still get the problem. the only programs that are running are bf2, aol,fraps and teamspeak which is the same as my other pc.
when i first installed this pc i had the prob and it was mcaffe that was causeing it, so i uninstaled that and now just have avg. it did work for a day then the problem came back.
my specs
asus a8n-sli premium.
amd 3700+
pny tech 1gig ddr 400hz
nvidia 3dforce 7600gs.
my specs
amd 3700+
