I am using a netgear DG834 router, and have the following statistics on my connection:
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 23 db 10.5 db
Noise Margin 14 db 25 db
My speeds are no faster than standard adsl however, at 512kb download.
Firmware has been updated to the latest version Firmware Version V3.01.25
but still no luck.
My package isn't limited to 512mb
The calculator from the sticky tells me "ADSL Line Capability Calculator
A crude estimate of what your line is capable of is 8192kbps (kilo bits per second).
This figure is based largely on your current Signal to Noise ratio, and current line speed. The results you may obtain in practice are likely to vary, and thus this figure should only be used to estimate your lines capability."
Also BT "how fast can i go" tells me i should get 8meg.
Any suggestions?
but still no luck.
Any suggestions?
