- 2 Nov 2015
So I recently bought a PS4 used (about 3 weeks ago) just to play the PS4 exclusives as I play most of my games on PC. Anyhow I was playing uncharted 1 when I accidentally pulled out the power plug for both the PS4 and TV. Now when I try to turn on the PS4 I get a signal but no display. The PS4 turns on fine and system is functioning as it should, only thing being that it doesn't display anything ( I know this because if I go into safe mode and I follow a guide on Youtube I can see what settings are where and follow them by counting the amount of times to press down on the D pad and across on the D pad, this enables me to restart the PS4 and not much else as I don't actually know what is going on. I think the issue is with the HDMI port as one of the pins is slightly shorter than the other pins (6th one on this specification page https://en.wikipedia.org/wiki/HDMI (TMDS Data1−)) but that has nothing to do with what happened, so I don't know any more. Going to buy a Torx 8 size screw to open the console as the smallest I have is Torx 10.
