Broke PC after GPU upgrade
27 Sep 2009
Upgraded to a 3090. Mbb is ASUS Maximus VIII Gene which gives a 00 code.
Reseated old GPU, checked all wires, RAM and power.
Still same 00 code.
00 code on asus is no cpu detected. Could also mean not getting enough power. re-seat cpu and maybe test again with old gpu and see if that boots in before putting the 3090 back in
Ok, so looks like the mbb was damaged. I got a new mbb (the exact same model) and it posts but no display is outputted using either HDMI or DP.
The 3090 works fine in a more modern PC.
I have not tried your motherboard before but I know that some default to outputting video using the inbuilt gpu, so first thing I would try is using the hmdi on the output panel on the back of the pc.
