broken dongle
5 Dec 2008
Peterborough
Hello all, for my original ps4 wireless headset i accidently stepped on the dongle now it does not work, any ideas what is the best replacement for the dongle. It came with the headset
I'm pretty sure that most bluetooth dongles work, I recall my creative X7 had it's own one so it's not limited to just official. There's nothing special about the official one to my knowledge.
You may find even a cheap 99p ones does the job
I see this topic come up at least once a week and every single time someone is telling the person the USB dongle is unique to each unit and can't be replaced. This is completely incorrect. I know all these people are just repeating what they have been told/read, but it's wrong.
Once you find a replacement USB dongle, do the following to pair it with your set.
  • 1 Connect the wireless adaptor to a PlayStation system or other powered USB port.
  • 2 Insert a small pin or similar object into the hole surrounding the reset button in the wireless adaptor, and push in for at least one second.
  • 3 On the headset, hold down the MUTE button and the VSS button.
  • 4 While still holding down the MUTE button and the VSS button, slide the power switch to position 1 or 2.
