- 23 Aug 2007
Well at least I broke down before getting on the motorway
The bike basicity stopped at a roundabout as I was trying to pull away and after that I could not start it again.
Before the RAC guy put the charger cables on it it had about 11 volts.
So after a quick charge the bike started fine again.
The rac followed me home and he did some tests after connecting his 12 volt battery to mine and my one was not charging very good still never hitting 14 volts on 3k-4k revs he said.
He said it could the regulator rectifier more then the battery.
I am not sure what to do buy a regulator or battery?
My bike a Yamaha XJ 600 2001 Diversion.
Thanks for a advice you can give me.
