Got a 08 Focus in workshop due to an intermittent fault of it cutting out past 70mph+, it was running when in. Unfortunately after a crank sensor was replaced (showed as faulty in diagnostics) the car would no longer turn over and even old sensor failed.
It was replaced but now the car no longer works. Everything has been checked and came out perfect other then ecu. Is it possible ECU could have failed during a simple sensor change?
