Broken extractor replacement
21 Nov 2008
This bathroom extractor fan is dead and im wanting to replace it for a regular one.
What's the easiest way to do this? Can I use the existing wiring?
Fan:
Transformer:
If you want it to be able to run on after you've turned out the lights you will need a 3 core cable.
Also the cable doesn't have an earth wire so a mains fan would need to be 'class 2'.
Doesn't need to run after the light is out.
Could I use the existing cable and a fan with a pull cord?
Oh it's on a 12v transformer.
In which case yes just but a new fan that takes 12v. The blue is your neutral brown live.
I had a quick eBay and couldn't find that exact model but if you search 12v wall extractor or whatever you could probably get a very similar one
Check the dimensions
But I reckon something like that would almost be a like for like swap
As its got a transformer you want to check its deffo the fan thats dead and not the transformer.
You want something 12v to add to the chockblock in the fan housing, something like a pc fan.
In my experience the transformers are just as likely to die than the fan itself.
Yea good point more than likely the transformer.
If the op had a meter would be very easy to tell.
It looks like there is a fused spur for both the transformer and the fan.
Can I not just strip away the transformer and use the cable that goes from there to the fused spur next to the fan (take out the fuse as do not need 2 fused spurs) and wire in a new fan?
If I get what you mean then yes. The 240v to the transformer is fine to use directly to a 240v fan. I wouldn't reuse the wiring from that transformer to the fan though, likely not 240v cable.
Where is the switch though, is the transformer unit acting as some kind of controller?
Some detect light switch coming on and/or sense humidity to control the fan.
That fan doesn't appear to be anything bar a switchless dumb fan
I replaced ours earlier in the year as it was way too loud the existing one. I went through several from the rainforest all claiming to be 'silent', sending them back until I got one that was actually quiet but with decent airflow....to save you some pain...
Ended up with this : Envirovent SIL100S. It's not silent (obviously) as it's shifting a fair bit of air, but is effective and quiet.
