- 10 Apr 2011
Hi guys im new around here, i have had my pc for over a year now and like a dummy i broke my fan cable connector when inserting it back into the motherboard.
This is the details i have about my fan:
Xigmatek 120mm Cooling Fans:
- Frame dimension 120 x 120 x 25mm
- Fan speed 1500 RPM
- Fan airflow 68.33 CFM
- Connector 3-pin
- Voltage rating 12V
- Noise level 20dB(A)
What cable should i buy from overclockers because i searched and i could only see one which was 60CM! Need help guys. Its definitely the cable as i connected my other fan to the motherboard connector and its working with that one.
http://www.overclockers.co.uk/search_results.php?sortby=&groupid=1929&search=3+pin+fan+cable
This is the only one i can see that should do the job if im correct (probably not lol)
Is it not possible to just replace the little white connector on the cable? Its loose when i connect it because i inserted it the wrong way around and broke it :S
Thanks
- Connector 3-pin
Thanks
