Broken Gas Oven Knob
7 Apr 2004
Hi,
Feel pretty silly asking this :p but how do I go about fixing a snapped gas oven control knob? It seems to be snapped very badly, I don't think it can be feasibly super glued back in.
It's a Cannon oven, outside of warranty.
Pic 1
Pic 2
So, should I try and track down an engineer to order & fit a new knob? Or excuse for new oven?
Ok thanks, so the snapped off bit that's stuck on the inside, should that just pull out? Wasn't sure if i would have to disassemble the front to get to it.
Should be able get it off either by splitting the remaining plastic shaft,(sometimes there is a small metal collar on the knob shaft) plastic most likely brittle, or use a pair of long nosed pliers to pull it off.
Pull off one of the other knobs,you will see what I mean.
