- 30 May 2012
- Bristol
The heater on my Peugeot 308 seems to be broken, the fans only blow cold air. Are there any simple and cheap things I can do to fix this or is it a job for a garage?
Possibly a daft question it have you got any water in it? Pugs love air locks so low coolant could be causing it
Air lock in/near the heater matrix, faulty heater matrix, low coolant, dodgy thermostat not opening and allowing coolant to enter the heater matrix, could be a few things.
Its probably because its a Peugeot though.![]()
All of these and more are common on peugeots, good luck OP, enjoy the winter!
Broken temperature selectors on the dash are common too, the fancy ones with climate control can have the control modules go down or the divert mechanism seize.
Don't get as many clogged matrix's as we used to, was always oddly satisfying to pull the pipes and put the jet wash through them... Don't judge me!
