Broken PCI-E lever lock
6 Apr 2015
UK
I have broken the PCI-E lever lock on the motherboard and I can't get my graphics card out, is there any other way?
try to use something to push what is left from it, but use something that is plastic or not metal otherwise you could damage your mb ou gpu.
I once had that happen. Tore it out with half of the PCIE slot still attached to the card.
The mobo slot still works fine...
...with an x1 card :p
