Hi there, My bro has just encountered an annoying problem. He tried to install NFS Carbon and it got to 39% and crashed.He reset the computer but now when you turn the computer on the post screen appears then after that it goes to the next screen (the "boot from cd..." screen) and will then just go back to the post screen. Basically it won't even get to the Windows XP loading screen. I'm thinking his installation of windows is borked but he doesn't want to have to format as its got his uni work on there :/
He did mention that the screen flashes on and off in between each screen (though I don't think that this is the problem) Temperatures are ok in BIOS (25C for system temp and 34C for the CPU).
He is using a A64 3000+, MSI K8n-neo2-fx, 2x512 DDR (generic)
Any takers?
Thanks in advance
kiz
Any takers?
Thanks in advance
kiz
