20 May 2008 at 10:27 #1 Neoni Neoni Soldato Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. my monitors is putting a brown tint on everything its a dell 2007wfp, its running off a macbookpro, any ideas why its doing it? -neoni.
20 May 2008 at 11:12 #3 Neoni Neoni Soldato OP Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. roozor said: ctrl + alt + cmd + 8 ? Click to expand... nope?
20 May 2008 at 11:46 #4 Neoni Neoni Soldato OP Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. its really annoying one screen seems to be fine the external colour is way off on pictures, but these forums look fine.
20 May 2008 at 12:01 #5 Beepcake Beepcake Soldato Joined 18 Oct 2002 Posts 3,896 Location Cheshire Can you try anything else on the same cable?
20 May 2008 at 12:04 #6 Neoni Neoni Soldato OP Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. Beepcake said: Can you try anything else on the same cable? Click to expand... tryed DVI-D and also VGA on the same monitor exactly the same.
20 May 2008 at 13:53 #7 ichabod crane ichabod crane Man of Honour Joined 14 Aug 2005 Posts 5,286 Location York tried connecting to another monitor? to clarify if its the display or the macbooks output
20 May 2008 at 14:07 #8 Neoni Neoni Soldato OP Joined 26 Dec 2004 Posts 13,323 Location Sweatshop. ichabod crane said: tried connecting to another monitor? to clarify if its the display or the macbooks output Click to expand... its wierd preview isnt showing me the true colours if images, but when i open them in aperture or photoshop all is fine.
20 May 2008 at 16:54 #9 Beepcake Beepcake Soldato Joined 18 Oct 2002 Posts 3,896 Location Cheshire Could be a colour profile problem.. check in the display settings and see what profile the monitor is using.
