Afternoon all
Not sure how to or what's gone on here to be honest.
I was playing Counter strike this morning fine surfing was fine also.
Then i went on to argos link and it couldn't find it ( the window you get when it can't find the link)
I checked the router thats fine , so i rebooted and it was still the same .
I tried another reboot of another drive that i use sometimes and that seemed the same too?
The strange thing is when i login to ftp servers it works fine and the same when using newsgroups?
I don't know whats wrong or how to solve this nothing looks wrong other than IE won't connect to the internet? And it also won't connect to my router as well via IE which i found odd?
I'm on win xp
Hence the reason i'm on works computer to post this.
Thanks..
I'm on win xp
Thanks..
