BSOD: 0x000000f4 ?
1 Feb 2009
Wiltshire
Hi guys, im having an issue with a system i built over a year ago, im getting this bsod during boot up and i cant pin it down at all.
i ran a check disk and it found errors, it fixed these errors, but still i have the same problem. :(
vista64bit
wd 250gb
amd dual core athlon
4gb ddr2 800mhz
nvidia 8400
500Wpsu
any help/advice is welcome
Download mem test to test the ram, just in case you have a faulty stick.
Is your system overclocked, try lowering if you not done so already.
