BSOD (0xA) (Info inside)
18 Oct 2011
Just received a BSOD while playing Roblox of all things, quick whoscrashed run reported this (below)..
On my old Intel system i believe 0xA was to do with memory if i remember correct? I did notice the memory is rated upto 1.4v and with XMP running it is currently on 1.35v
Dark Pro "8Pack Edition"
https://www.overclockers.co.uk/team...00c16-3600mhz-dual-channel-kit-my-002-8p.html
On Tue 08/06/2021 19:00:38 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\060821-7359-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F6C90)
Bugcheck code: 0xA (0xFFFFD880067D6339, 0x2, 0x0, 0xFFFFF80307F1A85A)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This is a software bug.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
