BSOD (0xD1)
18 Oct 2011
I have never had this BSOD Code before so I am assuming it is something to with me recently going from Windows 7 to Windows 8.1
On Tue 16/12/2014 14:51:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121614-4937-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x150AA0)
Bugcheck code: 0xD1 (0x0, 0x2, 0x8, 0x0)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
what was you doing at the time of this blue screen?
have any new drivers been installed recently which could have caused the issue?
I was playing a game and on the internet, It is hard to tell since i have recently installed windows 8.1 from Windows 7. I never had this BSOD on Windows 7.
ok, what might be the best option to do is to make sure all your chipset drivers and GPU drivers etc are all up to date and see if that helps.
