BSOD - 100000b8
8 Sep 2010
Kent
Good evening all,
I've been getting an intermittent issue which first surfaced whilst playing FM 2014. The system would slow to a near-stand still and eventually freeze within a ten second period. I put this down to maybe a memory leak issue and thought no more of it.
I've just had the same thing happen to me whilst playing Metro 2033 - I reset my PC and windows game me a "recovered from unexpected error..... 100000b8"
Any ideas what might be causing this error? The only recent changes are a new PSU (went for a Cosair 650 to a 750) and a second 680GTX. I've recently updated my BIOS to the latest to fix a soundcard issue but I had this freezing issue before that update.
Thanks in advance.
I've updated my GFX drivers and all windows updates - is there any other specific drivers I should look at?
I've just run a memtest and it passed with no errors. I'm running the scan you mentioned now.
Just to update - I've read that that enabling XMP on the RAM with 4 sticks can be a bit troublesome so I've switched that off. The perfomance mode (RAM) was set to turbo too, so I've set that to normal.
The RAM is now at stock and the CPU @ 4.5. I've taken the overclocks off of the GPUs and ran Heaven for around 3 hours with no problems.
A further update - after thinking that I had solved my issues, my system froze up after playing Batman AC for about 3 hours. The settings were maxed out (2xMSAA) in 3D vision. The frame rate suddenly started stuttering severely and eventually the system froze within a 15 second timeframe, requiring a hard reset.
I've been reading a thread i found on Google and have been thinking it could be my PSU. Is a 750w Corsair PSU enough for SLI 680GTX and an oc'd 3570K? Or could the PSU be defective?
It's probably heat. Take off the CPU overclock and see what happens. More than likely the GPUs are pouring heat into the case and are causing heat related stability.
I'm thinking of just doing a format this weekend - it will take out a lot of variables.
On a side note, I don't think it's heat/load based because the system crashes after few hours of football manager - which isn't very demanding.
