Bsod 7e
15 May 2012
Louth, lincs
With the above code, i have run chkdisk and scannow, but still getting it occasionally, does it solely mean os is corrupt?? Is it time for a fresh install??
this is the report that crashed pc
On Sun 27/01/2013 15:48:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012713-5194-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0xF0A94)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF88008564A94, 0xFFFFF8800A7B4078, 0xFFFFF8800A7B38D0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
