- 6 Jan 2013
- Rollergirl
I've done a clean install of 8.1, and I got a couple of BSOD when launching Crysis 3 tonight. GPU's are mildly OC'd and CPU is 4.6 @ 1.25 vcore.
I run Memtest for a couple of hours with no errors.
Any ideas?
Any ideas?
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Mon 06/04/2015 19:21:40 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\040615-5296-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1509A0)
Bugcheck code: 0xDE (0x2, 0xFFFFC000B2C4E928, 0xFFFFC000B2C4E829, 0x1B6EE98C0)
Error: POOL_CORRUPTION_IN_FILE_AREA
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a driver has corrupted pool memory that is used for holding pages destined for disk.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0xAF002)
file path: C:\WINDOWS\system32\drivers\ntfs.sys
description: NT File System Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Mon 06/04/2015 18:43:03 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\040615-5218-01.dmp
Bugcheck code: 0x1A (0x402, 0xFFFFC0006E4E9138, 0x1B6C198C0, 0xFFFFC000628BE4D9)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
