bsod after logging in
16 Mar 2007
hey all,
my bros sony vaio is having a problem, its seems after be uninstalled a program (dreamweaver i think). basically the problem is that itll load up to the login screen fine, but after logging in itll act like its loading, but will then bsod and restart. therell be times wen itll login and ill get an error message saying explorer must be closed, and has a button saying close
the screen will then have the background displayed bu no task bar or icons. i cannot execute much from run via task manager, only msconfig. iv tired system restore but it bsod before the utility starts. safe mode is no go either. sorry if im unclear.
any ideas?
thanks
If iexplore is ending it could be a virus such as MuscdriverV32. If you can log in check activity in the task manager.
Other than that, sounds like a repair install issue or system restore.
through msconfig i have changed the startup to the very basic, yet the problem still happens. as said before i cant get system restore to work. how do i go abouts doing this repair installation...
thanks
Just a question whilst trying to understand your problem, what are you referring to when you say: 'itll' ? are you talking about the Operating Software or the application you tried to remove or another application?
