Hi Guys
Wonder if any of you could shed light on this please
I am getting BSODs recently. The system (listed below) was fine for a month or so then suddenly developed the fault.
System
Win 7 pro 64
version 6.1.7600 Build 7600
CPU: Intel Core i5 760 2.80GHz @ 4.00GHz
Motherboard: Gigabyte P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard
RAM: Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Cooler: Akasa Nero S CPU Cooler
Graphics Card ATI RadeonHD 5600 series
see: http://www.overclockers.co.uk/showproduct.php?prodid=BU-023-OB
This is the OCUK overclocked bundle
PSU Antec TPQ1000
Crucial C300 SSD 64Gb holding OS
HDD Samsung Spinpoint f3 1T
Plus DVDRW
All the drivers are up to date
Have run memtest86+ and both memory modules seem ok
Bios is Ver F7
Dual HD monitor setup running hydragrid/actual window manager (6.3)/input director
WhoCrashed gives the following reports
On Sun 11/14/2010 1:26:29 PM your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0xA (0x96B, 0x2, 0x1, 0xFFFFF80003213DF2)
Error: IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\111410-17706-01.dmp
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Sun 11/14/2010 1:17:51 PM your computer crashed
This was likely caused by the following module: hardware
Bugcheck code: 0x124 (0x0, 0xFFFFFA800402E028, 0xB2000000, 0x10005)
Error: WHEA_UNCORRECTABLE_ERROR
Dump file: C:\Windows\Minidump\111410-13618-01.dmp
On Mon 11/15/2010 9:40:06 AM your computer crashed
Bugcheck code: 0x9C (0x0, 0xFFFFF88002FDBB70, 0x0, 0x0)
Error: MACHINE_CHECK_EXCEPTION
Dump file: C:\Windows\Minidump\111510-9921-01.dmp
On Mon 11/15/2010 2:38:20 PM your computer crashed
Bugcheck code: 0x101 (0x31, 0x0, 0xFFFFF880009E9180, 0x1)
Error: CLOCK_WATCHDOG_TIMEOUT
Dump file: C:\Windows\Minidump\111510-9609-01.dmp
On Mon 11/15/2010 4:05:59 PM your computer crashed
Dump file: C:\Windows\Minidump\111510-10108-01.dmp
So you can see the "Bug" is not always the same each time
Windows repair says there's nothing to repair - I was hoping for a corrupt ntoskrnl.exe or something
I am trying to stress test the video card but it can't finish before a BSOD! As I said the system was perfectly stable for about a month until yesterday!!
CPUID HWM/CPU-z don't show up anything untoward (can post the results if anyone can help).
The only thing which I have done that I can recall was loading Steam and downloading/playing some games (Arx Fatalis and Dragon Age) but the BSOD do not just happen if just playing a game for instance the above stress test
Any guidance would be truly appreciated!
Thanks
Nick
System
Win 7 pro 64
PSU Antec TPQ1000
Plus DVDRW
Bios is Ver F7
Thanks
Nick
