I'm currently running a intel core 2 quad q8200 @2.33ghz with nvidia 9500gt graphics card and other cheap parts.
When booting it will get to the microsoft logo and then restart and ask if I want to launch start up repair and I keep saying no and it will repeatedly blue screen or restart about 2-6 times and then it will eventually turn on and work properly and then it may blue screen once a day whilst being used.
Occasionally when I manage to get onto the desktop the screen resolution is not as it should be as I believe the graphics card does not work/load the drivers and requires a restart to then go back to normal.
Below are all the bluescreen filenames that have had issues:
Contant:
ntfs.sys
ntoskrnl.exe
Occasionally:
ataport.sys
rdyboost.sys
tcpip.sys
CI.dll
partmgr.sys
nvlddmkm.sys
ndis.sys
ndiswan.sys
fltmgr.sys
I had this problem before and reinstalled windows 7 and has the same fault so then removed one ram stick and it worked perfectly for a couple of months. Each ram stick works by itself but not together, these have been working together for about 3-3 and a half years before they started playing up.
Another point to note is that when I connect two devices in the front usb port one may drop out and not be powered anymore and sometimes they'll both be powered. I'm guessing this could be a power fault which is causing all these issues?
Any help would be greatly appreciated!
Contant:
ntfs.sys
ntoskrnl.exe
Occasionally:
ataport.sys
rdyboost.sys
tcpip.sys
CI.dll
partmgr.sys
nvlddmkm.sys
ndis.sys
ndiswan.sys
fltmgr.sys
