BSOD d1
3 Jun 2012
hey
getting a lot of BSOD today, all with code ending d1.
My Overclock seems to be stable as its been running prime 95 for an hour with no errors.
4.5ghz @ 1.232V
I thought it might be my GPU overclock so i removed it, yet the BSOD still happens after 10mins+ ingame
Last thing i think it could be is my memory, I'm currently backing up my only spare USB stick to use memtest on it so will update when that's done.
I am running a fresh install of windows 7 ultimate 64bit
left memtest running, did an entire 5 hour run through, No errors at all.
So.. will leave Prime95 and Kombuster on over night... will see what happens.
Update
Left Kombuster running and prime 95 running over night... 12 hours later its still running albeit warmer than i like but hey its stable.
Does anyone know what on earth is causing my system to crash in games?
Have you tried running something like WhoCrashed to analyze your crash dumps? It should give some more information about the crash and can tell you which driver (assuming it's a driver issue) which is causing it.
0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage
Also check event viewer for any WHEA-Logger Errors which will mean more vcore even tho your p95 stable.
Thanks you two. I will get that program and have a look and post my findings.
Will also increase the volts on mem to 1.52 from 1.5 and add .010 to the cpu. Will see if that sorts it
Checked the Event Viewer, and a lot of WHEA-Logger Errors :/
This is what WhoCrashed Says:
On Sun 05/05/2013 17:26:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050513-27939-01.dmp
This was probably caused by the following module: usbport.sys (0xFFFFF880051AC5CD)
Bugcheck code: 0xD1 (0x28, 0x2, 0x0, 0xFFFFF880051AC5CD)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\usbport.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: USB 1.1 & 2.0 Port Driver
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Seems its a USB issue? o.O
