BSOD dump advice?
2 Aug 2010
London
Hey guys, i had flashed my motherboards bios and all went fine, and later on i played a game of BC2, i then encountered a BSOD and i was wondering if anyone could take a look for me and offer a course of action.
not at the time, but ive got the bug check code, the parameter's and a possible cause from having a look at the minidump.
The bug check code was 0x00000124
Heres the text from the bsod,
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: hal.dll
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x00000124 (0x0000000000000000, 0xfffffa8005e0b028, 0x00000000b201a000,
0x0000000000000175)
*** hal.dll - Address 0xfffff80002e19a3b base at 0xfffff80002e07000 DateStamp
0x4ce7c669
