BSOD errors when playing BF3
21 Mar 2012
Hi
I was hoping someone could help with the problem i am having with my pc,i keep getting these BSOD errors when i play BF3 online,system specs are...
MS Windows 7 Home Premium 64-bit SP1
CPU
AMD Phenom II X4 830 33 °C
Deneb 45nm Technology
RAM
4.00 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
FOXCONN 2AA9 (CPU 1) 25 °C
Graphics
Generic Non-PnP Monitor (1024x768@60Hz)
AMD Radeon HD 6800 Series
Hard Drives
977GB Western Digital WDC WD10 01FAES-60Z2A0 SATA Disk Device (SATA)
Optical Drives
hp BDDVDRW CH20L SATA CdRom Device
Audio
Realtek High Definition Audio
Operating System
Dump errors....
Dump File : 031212-18642-01.dmp
Crash Time : 12/03/2012 18:43:11
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Parameter 1 : ffffffff`c0000005
Parameter 2 : fffff880`02f8ccf7
Parameter 3 : fffff880`023fe6a8
Parameter 4 : fffff880`023fdf00
Caused By Driver : srv2.sys
Caused By Address : srv2.sys+fe7b8000
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : dxgmms1.sys+20cf7
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\MiniDump\031212-18642-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7601
Dump File Size : 287,352
Dump File : 031112-32229-01.dmp
Crash Time : 11/03/2012 18:41:38
Bug Check String : BAD_POOL_HEADER
Bug Check Code : 0x00000019
Parameter 1 : 00000000`00000020
Parameter 2 : fffffa80`043b6000
Parameter 3 : fffffa80`043b6410
Parameter 4 : 00000000`04410000
Caused By Driver : rdprefmp.sys
Caused By Address : rdprefmp.sys+275f1df
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7cc40
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\MiniDump\031112-32229-01.dmp
Major Version : 15
Dump File Size : 287,160
Dump File : 031112-34039-01.dmp
Crash Time : 11/03/2012 17:28:32
Bug Check String : SYSTEM_SERVICE_EXCEPTION
Bug Check Code : 0x0000003b
Parameter 1 : 00000000`c0000005
Parameter 2 : fffff800`02ec1b65
Parameter 3 : fffff880`0b70b110
Parameter 4 : 00000000`00000000
Caused By Driver : monitor.sys
Caused By Address : monitor.sys+4ae0110
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\MiniDump\031112-34039-01.dmp
Major Version : 15
Dump File Size : 286,968
These are some of the dump files i have and there are a few more also,it is way over my head what is causing this can any of you guys help,thanks in advance.
here are a few of the other bsod dump files...
Dump File : 031112-29296-01.dmp
Crash Time : 11/03/2012 16:05:51
Bug Check String : PFN_LIST_CORRUPT
Bug Check Code : 0x0000004e
Parameter 1 : 00000000`00000099
Parameter 2 : 00000000`0008de6c
Parameter 3 : 00000000`00000002
Parameter 4 : 00000000`0002c1bd
Caused By Driver : USBD.SYS
Caused By Address : USBD.SYS+fffd1230
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\MiniDump\031112-29296-01.dmp
Major Version : 15
Dump File : 031012-23415-01.dmp
Crash Time : 10/03/2012 09:26:28
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 00000000`00000008
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000001
Parameter 4 : fffff800`02ee1a26
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+7cc40
File Description : NT Kernel & System
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7601.17640 (win7sp1_gdr.110622-1506)
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\MiniDump\031012-23415-01.dmp
Major Version : 15
Dump File Size : 286,200
Dump File : 030812-29577-01.dmp
Crash Time : 08/03/2012 21:13:32
Parameter 1 : 00000000`00000040
Parameter 4 : fffff800`02e94e38
Caused By Driver : afd.sys
Caused By Address : afd.sys+2c640
File Description :
Product Name :
Company :
File Version :
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\MiniDump\030812-29577-01.dmp
Major Version : 15
Dump File : 031212-27144-01.dmp
Crash Time : 12/03/2012 19:29:54
Parameter 1 : 00000000`000000a8
Parameter 4 : fffff800`02ea6e77
Processor : x64
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\MiniDump\031212-27144-01.dmp
Major Version : 15
Dump File Size : 286,520
This game really does not like Antivirus software. I use Bitdefender, and with that active I cannot play BF3, I know also that AVG causes massive issues with it, so it stands to reason that a good place to start is, as RevBillyG states, with Norton.
Thanks for the reply,norton is on my pc but it is not active as it was pre installed on the pc for a trial,once the 3 month trial was over i never upgraded to a new membership ,i have played bf3 since the launch with no problems so why would it cause problems now?all these bsod crashes have different codes and reasons, you would think if it was norton they would all be the same,i have had say 10 crashes all with different driver errors or system errors,what can cause this.
Doesn't matter that it's not "active". It hooks into sys DLLs. It's worse than most viruses imo.
It's a complete arse to remove, and if it were my PC, I'd simply re-install Windows rather than faff around with the Norton Removal Tool.
Either uninstall (if it lets you) or do a Winstall, and use Microsoft Security Essentials instead.
*edit*
Using a 68** card at 1080x760 should be illegal, get yourself a nice new monitor :p
i run bf3 at 1080x1020 though,i changed the ram with new gskill ram,so that rules that out,can it be gpu,psu cpu .its back in the shop for repair they charged me £50 to check the pc and install the new ram,i told them beforehand it wasnt the ram as i previously had 8 gb in and swapped it for a different 4gb i had in the house,any other ideas guys.
