BSOD help please
24 Jul 2022
uk
Hi guys, i really need some expert help here and would appreciate your input very very much, recently i started getting bsod's when gaming radomly every now and then, everything is at stock and temps on the main hardware components is fine as far as i can see (gpu,cpu)
i'm no expert regarding bsod's so don't understand what the dumps mean, i'm sure it's hardware related but not sure what part, memtest was passed overnight so not that as far as i can see,
i'm going to post the dmp file here so excuse the long text and really would appreciate any help from you guys, i'll also upload the file, thanks. EDIT: can't seem to see where to attach files
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffc48cb7b33028, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 00000000bc800800, High order 32-bits of the MCi_STATUS value.
Arg4: 00000000060c0859, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 3140
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 9120
Key : Analysis.Init.CPU.mSec
Value: 1625
Key : Analysis.Init.Elapsed.mSec
Value: 58185
Key : Analysis.Memory.CommitPeak.Mb
Value: 99
Key : WER.OS.Branch
Value: co_release
Key : WER.OS.Timestamp
Value: 2021-06-04T16:28:00Z
Key : WER.OS.Version
Value: 10.0.22000.1
FILE_IN_CAB: MEMORY.DMP
DUMP_FILE_ATTRIBUTES: 0x1000
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P2: ffffc48cb7b33028
BUGCHECK_P3: bc800800
BUGCHECK_P4: 60c0859
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: AC2-Win64-Shipping.exe
STACK_TEXT:
ffff9a01`35927948 fffff801`6af0195b : 00000000`00000124 00000000`00000000 ffffc48c`b7b33028 00000000`bc800800 : nt!KeBugCheckEx
ffff9a01`35927950 fffff801`6ee010c0 : 00000000`00000000 ffff9a01`35927a29 ffffc48c`b7b33028 ffffc48c`b7b33028 : nt!HalBugCheckSystem+0xeb
ffff9a01`35927990 fffff801`6b03fae3 : 00000000`00000000 ffff9a01`35927a29 ffffc48c`b7b33028 ffffc48c`afefbbf0 : PSHED!PshedBugCheckSystem+0x10
ffff9a01`359279c0 fffff801`6af0334d : ffffc48c`b6989900 ffffc48c`b6989900 ffffc48c`afefbc40 178bfbff`7ef8320b : nt!WheaReportHwError+0x393
ffff9a01`35927a90 fffff801`6af03798 : 00000000`0000000f ffffc48c`00000000 00000000`00000000 00000000`0000000f : nt!HalpMcaReportError+0xb1
ffff9a01`35927bf0 fffff801`6af0362c : ffffc48c`afd52b40 6f6e6e61`00000000 ffff9a01`35927e00 20534f44`00000000 : nt!HalpMceHandlerCore+0x138
ffff9a01`35927c50 fffff801`6af02acb : ffffc48c`afd52b40 ffff9a01`35927ef0 00000000`00000000 ea3ca594`eb38d748 : nt!HalpMceHandler+0xe0
ffff9a01`35927c90 fffff801`6af0544b : ffffc48c`afd52b40 00000000`00000000 00000000`00000000 000a8664`00004550 : nt!HalpHandleMachineCheck+0x97
ffff9a01`35927cc0 fffff801`6af65849 : 00007000`1c0e020b 00000000`0000f000 00001000`00000000 00000001`c0000000 : nt!HalHandleMcheck+0x3b
ffff9a01`35927cf0 fffff801`6ae278fe : 00000000`0000000a 00001000`00017000 41600001`000205a3 00000000`00040000 : nt!KiHandleMcheck+0x9
ffff9a01`35927d20 fffff801`6ae27528 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7e
ffff9a01`35927e60 00007ff7`bd1c37f8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x2a8
00000058`4e71e9b0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff7`bd1c37f8
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD.sys
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x124_0_AuthenticAMD_MEMORY__UNKNOWN_FATAL_IMAGE_AuthenticAMD.sys
OS_VERSION: 10.0.22000.1
BUILDLAB_STR: co_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {b0905187-9dbc-d607-4dc5-8630b9eddb7f}
Followup: MachineOwner
you can download a program called WhosCrashed which may help you find out what the issue is. You will need to start with hardware and remove/add to see if that resolves the issue.
thanks i'll try that
you should also monitor temps. Have you tried a fresh install of windows?
monitor ram temps? i have afterburner monitor gpu and cpu temps, they seem fine, windows install is about 6 months old
Monitor all temps. CPU, GPU, ram, storage. If its happening randomly while gaming it could be any of things. Has the case got good airflow? Could it be related to recent ambient high temps ?
Maybe download ddu and wipe all GPU drivers and reinstall
I had similar issues when I got my 5800X. Might be worth trying Level 1 Load-line calibration (LLC) in the BIOS.
Ryzen Clock Tuner reported excess vdroop (low voltage) and wouldn't run at default settings. LLC on both CPU and SOC completely solved it for me, no crashes whatsoever since.
Morherboard Bios up to date ?
yes i updated it
i'll try this right away, thanks for the suggestion
yes i updated it
Have you had any luck? I have a similar issue but my BSOD is Critical_Process_Died.
I actually bought a new M.2 and did a fresh install but it's still happening. I had it happen during a game, then it rebooted and happened twice more a few seconds after getting in to Windows.
I removed my RAM and IF overclock which made no difference. I'm currently running with 1 stick of RAM removed.
time will tell, the bsods are random, about twice a week
One other issue I had with my 5800X turned out to be an over-tightened CPU cooler. My chip went back to OCUK for testing- it was fine. My cooler was too tight and causing the RAM to misbehave, which apparently is a thing....
Sounds weird, but maybe worth a try to remove and re-seat with minimal pressure.
(Symptoms were a straight refusal to boot (DRAM led red) with any ram in dual-channel. Single stick still worked, but anything in B channel was no-go)
i'm aware of overtightening, that's why i i only go to when the screw stops and not carrying on
