Hey guys, Ok so I built my computer for nearly 2 years, and it has BSODed once or twice every few months. it killed my first GPU that had artifacts tht lasted 8 months(shuts off when playing flash video or games). Now luckily my current card is still working for the past 14 months. Although it now mostly shut down when on game.
Can anyone identify what the problem is? I thought it could be faulty RAM but could also be software driver bug. I really want to resolve this problem so any tips would be appreciated.
Heres the log over recent months-
On Thu 01/08/2013 22:09:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080113-23727-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75C00)
Bugcheck code: 0x109 (0xA3A039D8986DA709, 0xB3B7465EEAEA765F, 0xFFFFF80002146E50, 0x1)
Error: CRITICAL_STRUCTURE_CORRUPTION
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that the kernel has detected critical kernel code or data corruption.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Sat 27/07/2013 00:12:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072713-27768-01.dmp
Bugcheck code: 0x1A (0x3452, 0x7FEFB0E1000, 0xFFFFF70001085EB8, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
On Sun 14/04/2013 19:44:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041413-27799-01.dmp
Bugcheck code: 0x50 (0xFFFFF8A00BF84B30, 0x0, 0xFFFFF80002347CBD, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
On Wed 02/01/2013 19:25:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010213-25786-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7EFC0)
Bugcheck code: 0xA (0xFFFFF6800003EDB8, 0x0, 0x0, 0xFFFFF800020BF99B)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
