Within the past couple of weeks i have built myself a new rig as my last pc blew up (unfortunate i know). Anyway i have started experiancing a few problems which im starting to think is hardware related.
problem one:
when playing a game, for example call of duty world at war after a fairly reasonable amount of time, roughly a hour or so of play. The pc will BSOD and read a message, which i have not been able to make a note of as yet. i knw it starts with something along the lines of "if this is the first time you are seeing this message please check..." and thats as far as ive managed to read.
problem two:
simply watching a film or videp clip the pc will become non responsive and then appear to crash, sound will loop/stutter etc. The only way of fixing this problem would be to restart the computer.
i have checked my event viewer which reads:
system error, source: Diagnostics-Performance,it goes on to state boot up times etc...
what would cause these problems to occur and how would i go about resolving them? pc spec at the bottom
TIA
problem one:
problem two:
TIA
