Hello, new here. Decided to start my account with a bang and ask for help.
Since a week or so back I have been having issues with BSOD and I believe it is GPU related, most likely driver related.
I have an 980 ti if that matters any and it was fine until a few days ago which makes me believe it's driver related since I've been swapping drivers 1-3 times and even more after hoping it was version specific but to no avail.
As it seems, I never get BSOD while using the computer, but it seems to happen when the computer monitor goes off after 15 or 30min of no activity. It doesn't happen right away but it happens when I actually turn off the monitor too but it only happen after quite a long while so usually if I keep my computer on and go to bed I wake up to it. I never actually get to see the blue screen but If I turn the monitor on and shake the mouse it will react after 10-15ish seconds and restart itself and tell me something along the lines of Windows having recovered from an unexpected shutdown.
BCCode: 3b
BlueScreenView tells me it's caused by nvlddmkm.sys+96960 (which is nvidia but the number differs everytime).
I have gone through the DDU ordeal plenty of times for this to be not related to remaining scraps from old drivers etc.
I don't have any reasonable recovery points in windows that are a better temporary option that completely reinstalling Windows.
I am going to reinstall Windows next week when rebuilding my computer in a new case with a new drive but that's out of the question for now.
Some people have had issues with power saving function which I did double check but it seems to be alright but I might've missed something since recreating the issue is through hibernation it seems.
Any of you guys have any ideas?
BCCode: 3b
