BSOD - Just a bit of advice please (poss memory)
8 Sep 2011
Derbyshire
Hi.
Can some one help with this, I also have a mini dump, but I cannot read it, nor have the program to do so.
I cannot upload it because it is not the right file extension, I think its my RAM, but just wanted to be sure.
Booted up fine, then when I put my password in for the Desktop......BAM...got hit with this BSOD three times in a row.
This is the info I got on a pop up once it got into the Desktop on the fourth attempt.
I am online now with this PC and no issues....strange...
Much Appreciated.
Revo.
I have oc`d my FX8350 to 4.5, and have 4x4GB of ram,sat at [email protected].
If I xmp it up to [email protected] for its top profile then the pc hates it, I think I need 2x8GB of better ram rather than populating all four slots on a decent cpu overclock, I just wanted some memory advice as its not my strong point.
If you can think of anything I`ll give it a try..
Corsair CMX4GX3M1A1600C9
RAM
Memory slots
Total memory slots 4
Used memory slots 4
Free memory slots 0
Memory
Type DDR3
Size 16384 MBytes
Channels # Dual
DRAM Frequency 668.9 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Bank Cycle Time (tRC) 41 clocks
Physical Memory
Memory Usage 16 %
Total Physical 16 GB
Available Physical 13 GB
Total Virtual 32 GB
Available Virtual 29 GB
SPD
Number Of SPD Modules 4
Slot #1
Type DDR3
Size 4096 MBytes
Manufacturer Corsair
Max Bandwidth PC3-10700H (667 MHz)
Part Number CMX4GX3M1A1600C9
SPD Ext. XMP
XMP-1600
Frequency 800 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 24
Voltage 1.650 V
JEDEC #4
Frequency 666.7 MHz
CAS# Latency 9.0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 24
tRC 34
Voltage 1.500 V
JEDEC #3
Frequency 592.6 MHz
CAS# Latency 8.0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1.500 V
JEDEC #2
Frequency 518.5 MHz
CAS# Latency 7.0
RAS# To CAS# 7
RAS# Precharge 7
tRAS 19
tRC 27
Voltage 1.500 V
JEDEC #1
Frequency 444.4 MHz
CAS# Latency 6.0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 23
Voltage 1.500 V
Pulled that off `Speccy`.
Thanks.
Revo.
You need more CPU northbridge voltage as xmp won't increase that (memory controller) no idea how much on amd though,but id try two or three clicks more than what auto uses
