BSOD Memory Management.
15 Feb 2011
So I built my rig about 2 months ago and it seems problems keep occuring.
The problem now is MEMORY_MANAGEMENT.
So I've run the Windows Memory Diagnostic Test and nothing has come up.
Hoping the RAM is okay because it's all new.
Thinking of just wiping the PC and re-installing Windows.
Can only go to desktop now in safe mode.
Any ideas?
When running the tests make sure you only have ONE STICK of ram in!
Test each stick on their own to make sure which one maybe faulty.
Could also be a problem with some sort of software conflicting.
Got it work since testing the memory.
No problems once testing each on their own either.
Most likely stop working in a few days though.
If that is the case, the could be a dodgy windows installation. Sometimes happens.
What memory are you running and have you overclocked it in any ways?
