BSOD memory_management
15 Jan 2004
UK
Hi,
I just had a BSOD which gave the information that memory_management was the problem or cause. After that it said Stop: 0x0000001A.
I've no idea what might have caused this. Id be grateful for any ideas.
My system: intel 2500k, asus sabertooth p67, corsair vengeance 2x4gb, windows 7 home, asus geforce 560Ti, asus xonar DX soundcard. Everything is running at default. On assembling my system, I ran memtest86+ for 9 hours and it reported no errors.
Thanks for help.
Test your HDD also with the relevant tool and run Memtest again. If your still at a loss then run Whocrashed and report back.
Is your ram running at the correct voltage? I know with my OCZ ram, it needs 2.1/2.2v, my BIOS default is 1.8. It's unstable unless I set it to +0.4v
-Check the Corsair website :)
Thanks for the replies. I ran a fast whocrashed and the report was this:
On Sat 17/09/2011 17:00:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091711-16489-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40)
Bugcheck code: 0x1A (0x41287, 0x30, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Ill check my HDD, run memtest again and the volts too.
