BSOD (MEMORY_MANAGEMENT)
27 Jul 2020
Bought 32gigs of ram 3600mhz and put them in a system and was having recurring memory problems. Have just now put them in a new system and have started getting BSOD MEMORY MANAGEMENT. I ran them both on XMP on both systems. Do i need to do something with voltages or other fixes?
A) what memory modules are they?
B) what motherboard have you put them in?
C) Are you overclocking them or running stock?
D) Have you reset the bios and upgraded it to the latest version?
Corsair Vengeance LPX 32GB 3600mhz
First board was a x299 raider but I was already having issues with it , New board is a B550 Tomahawk.
I'm using xmp to get desired speeds.
Updated bios on the new board
Assuming you tried different dimm slots and out each stick in at a time see if you get the BSOD.
then Run memtest and see what it says. Chances are faulty sticks
