BSOD nvstor32.sys
16 Jul 2008
Hi,
I had some issues with my machine and I bought a new hard drive to install a fresh copy of Vista onto. For simplicity, I removed my other four hard disks before I did anything else. I've installed it all and done a full windows update. I plugged the other four disks in and now I get an IRQL_NOT_LESS_OR_EQUAL (0x000000d1) BSOD in nvstor32.sys within 30 seconds of logging in. I can sometimes get on My Computer and it shows all five drives.
The problem is that even if I get onto the device manager, the instant I click anything to do with my disk or controller it bluescreens. I am currently in the process of a repair operation, as the last one killed a boot file (winload.exe).
I'm running Windows Vista Ultimate 32-bit OEM on an Asus P5N32-E board, 4GB of PC2-8500 Corsair Dominator, an Intel Core 2 Duo E6600 and SLI'd BFG 8800GTX OC2 768MB cards. My disk drives are all SATA, and my DVDRW runs on IDE.
Any ideas how to fix this?
it looks as its a nvidia forceware driver problem uninstall the mobo drivers and restart computer F8 into safe mode and use driver cleaner to get rid of the leftover nvidia files and reboot to normal windows and reinstall the driver.
hope this works for you
