BSOD on £1100 rig, pls help
18 Oct 2002
Andover, Hampshire
Right i recieved my shiuny new pc and assebled it but i have a slight problem, in windows surfing or low end stuff its fine, but if i try to play a game i get the dreaded BSOD. But i cant find out why? i have the following kit
Q6600 cpu
Asus P5K Premium
2x2GB OCZ reaper 800mhz
OCUK value 8800GTX (my god its huge)
and 2 Seagate 500GB 32mb cashe HDD's
Windows Vista Ultimate 64bit edition
is there a program that i can get that will record what happens if something fails?
Please help, i really dont know what to do.
If its only happening in games, it sounds like either something is overheating or the PSU is either broken or not powerful enough.
What PSU does it have?
has the second hdd been formatted?
have you tried looking in computer management > disk management for the hdd?
are voltages correct?
what PSU are you running?
Ok, its happeningin widows too (i probably just wasnt in windiws long enough to see it happen)
How do i find out what voltage my ram is? is it through the bios? can i do it from Windows?
you find out and set it in your Bios, DDR2 ram voltages is normally about 2V, but it may vary a bit for each brand
it doesnt like something had to manually reset the pc to get back to windows.
But have noticed 2 things that might help you lot help me;
1) cant find RAM voltage anywhere but i have the following
VCORE voltage 1.224v
3.3v voltage 3.312v
5v voltage 4.968v
12v voltage 11.928v
2) when i get hat BSOD and i eventually get it back to post - it can come up with "overclock failed! press F1 to enter setup F2 to restore default bios"
But i havent overclocked it at all
What do i do now?
The black bracket on the OcUK GTX can be removed, then it'll just be standard size.
Set the voltage to 2.1v and timings to 4-4-4-15.
If that doesn't work, you can always run Memtest as already suggested, to eliminate a RAM fault.
