- 23 Jun 2008
Last night I put together a PC for the first time in my life and everything seemed to be going brilliantly. Turned it on and was greeted by all the correct messages etc.
Then came the Windows installation. This did not go well.
I have reinstalled Windows Vista Home Premium 32bit three times in total, tried to use the repair function on the installation disc twice but still doesn't help.
I keep getting regular BSOD's, only they go past so damn quickly it's difficult to read even the first line. I recall one of them had the words MEMORY_MANAGEMENT at the top and another one said something like IRQL_NOT_LESS_OR_EQUAL or something like that and I have no idea what's wrong with it.
To make matters worse, my friend also built his computer last night using exactly the same components as me and his worked perfectly!!! The only difference was the DVD drive, his was a Sony, mine a Samsung.
Any advice you could give me will be greatly appreciated.
