Hey guys,
I have recently been experiencing a very weird problem with my new build. As some of you may know, I have been overclocking my Q6600 perfectly happily over the last few weeks (see here), but am now experiencing regular BSODs.
Here is the problem, if I am using my PC normally I rarely get a BSOD, and can play games and browse the web with no difficulties. However, if I am to leave my PC idle for about 20-25 minutes, I come back to find my PC restarted, after a BSOD. Microsoft tells me that my PC has experienced a serious error, and directs me to this page. Since it is stated as a driver error, I started by re-installing my Nvidia drivers, to no avail. I then thought that it was probably a piece of adware, spyware or a virus. I ran all the various scans and it found some things, but my PC continued to blue screen. I then tried to restore my PC to a few weeks back, but it didn't work, even in safe mode.
I have been researching online, and found out that it could be a RAM issue, so I ran MemTest with all my overclocking off. There were 314 errors after 3 hours and 15 minutes. I assume that this is the RAM with the errors, as I have never used MemTest before. See the following pictures (click to enlarge):
I then thought of checking what the blue screen error was, it is this:
*** STOP: 0x0000007E (0xC0000005,0x804E4323,0xBACF7BBC,0xBACF78B8)
So, I now know that there is a fault with the RAM, but cannot be sure that it is causing the blue screens. I didn't run a MemTest when I first installed the RAM, so it may well have always been fautly, and since I never altered any RAM timings whatsoever when overclocking, I am confused as to how I could have done this to my RAM. Right now, I have switched off all my overclocking, but I was previously running these settings:
Q6600 (G0) @ 3.6GHz
FSB: 400
CPU Ratio Setting: 9
Vcore: 1.375v
NB Voltage: 1.31V
I once went up to 450 x 8 for about an hour, it ran stable but I decided against keeping those settings, and put the multiplier back to 9.
So, this is the RAM that I am using, but I really don't understand how it could be a RAM problem if I can use my computer normally when I don't leave it idle, I am even posting now on the same PC.
Whatever happens, I am going to need to buy some new RAM, which is annoying. However, I really would like to know if overclocking could have been the cause of the MemTest errors, and know definitely whether the RAM is causing the blue screens...or not. If you want me to carry out any other tests I am perfectly willing to do so.
Any help is always appreciated!
Chalex4
Q6600 (G0) @ 3.6GHz
FSB: 400
Vcore: 1.375v
NB Voltage: 1.31V
Chalex4
