Yo,
2 days ago i bought
"Krypton Z77 660i" Intel Core i5 3570K 3.40GHz @ 4.40GHz DDR3 Ivybridge Overclocked Bundle - 8gb Ram
ZOTAC GeForce GTX 560Ti "448 Edition" OC 1280MB GDDR5 PCI-Express Graphics Card
OCZ ZT 650W '80 Plus Bronze' Modular Power Supply
Kingston 120GB SSDNow V+200 Drive SATA 6Gb/s - (SVP200S3/120G)
Using old 320gb Hard Drive + Case and a new Dvd drive.
Basically when i put all my PC together yesterday and installed windows 7 + all the drivers for my hardware, I've had 5 BSOD, 2 whilst i've been playing Heroes of Newerth and 3 when I've been browsing Firefox. And since i've had these my games such as HoN have just been crashing, and Counterstrike:GO has been crashing too and the times that it hasn't crashed it was making a funny noise every 10 seconds that i can't really describe apart from the last part of the noise sounded like a static sound/crackling.
I've spent £750 on new parts to be able to play my games with no problems, yet at the minute i'm having more problems then my old components did!
Any help would be much appreciated.
(BSOD Mini Dumps Below)
System Information (local)
computer name: AARON-PC
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8550346752 total
VM: 2147352576, free: 1989447680
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 21/08/2012 22:08:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082112-12214-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x71F00)
Bugcheck code: 0x7F (0x10, 0x80050033, 0x406F8, 0x72FC48EC)
Error: UNEXPECTED_KERNEL_MODE_TRAP
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Tue 21/08/2012 19:44:49 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082112-13603-01.dmp
This was probably caused by the following module: hal.dll (hal+0x126E0)
Bugcheck code: 0x9C (0x0, 0xFFFFF880009F2B70, 0x0, 0x0)
Error: MACHINE_CHECK_EXCEPTION
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal machine check exception has occurred.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Tue 21/08/2012 17:35:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082112-12261-01.dmp
On Tue 21/08/2012 17:26:09 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082112-12948-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12903)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007993028, 0xBE000000, 0x800400)
Error: WHEA_UNCORRECTABLE_ERROR
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
2 days ago i bought
Crash Dump Analysis
