9 Mar 2020 at 16:56 #1 BriT BriT Soldato Joined 27 Jun 2005 Posts 5,320 Location Reading Hello I've been getting this error occasionally when at idle and not sure what to do about it? There's a new windows 10 update, version 1909. I'm currently 1903, shall I install the new update? Thanks
9 Mar 2020 at 17:24 #2 Joxeon Joxeon Soldato Joined 15 Oct 2019 Posts 13,412 Location Uk BriT said: Hello I've been getting this error occasionally when at idle and not sure what to do about it? There's a new windows 10 update, version 1909. I'm currently 1903, shall I install the new update? Thanks Click to expand... Do you get the error when everything is stock?
9 Mar 2020 at 17:26 #3 BriT BriT Soldato OP Joined 27 Jun 2005 Posts 5,320 Location Reading I haven't tried, had the overclock for two years. Maybe I should increase the voltage slightly.
9 Mar 2020 at 19:06 #4 Freddie1980 Freddie1980 Soldato Joined 25 Sep 2009 Posts 10,341 Location Billericay, UK Trying installing the latest version of Windows to a separate partition, it could a faulty driver on your current version is causing the issue.
9 Mar 2020 at 19:54 #5 BriT BriT Soldato OP Joined 27 Jun 2005 Posts 5,320 Location Reading How do i do that? sorry never set up a partition.
9 Mar 2020 at 20:49 #6 EsaT EsaT Soldato Joined 6 Jun 2008 Posts 11,634 Location Finland Check if there are memory dumps, which coudl cause hints about cause. https://www.resplendence.com/whocrashed https://www.nirsoft.net/utils/blue_screen_view.html Though might well be that overclocking isn't entirely stable/something is degrading.
