since iv built this new pc running in 32bit vista i have had no BSOD,s then i buy another 2GB of ram and vista 64bit and since a few days ago i keep getting BSOD when using msn and windows media player. it says PFN_List_Corrupt?
Iv used windows memory diagnostics and nothing was found to be wrong. iv just burnt the latest copy of memtest to a cd and ran it for a while and it came up with a lot of errors it got to 500+ errors and then i esc'ed and restarted. tonyt im planning on running it over nyt.
What i want to know is, if once memtest is finished, and i get a full list of the damage, what can i do about it ?
Cheers
<TommyG>
Cheers
<TommyG>
*** u mean RMA them ? the new sticks are the same make and model as the orignial 2 i bought, the timings of the ram is 4 4 4 15, but when i first put them in the motherboard, the motherboard had them up as 5 5 5 15 ? maybe i **** change it back to the motherboards settings ?
