I have a problem with my computer that is, when my computer is perfectly idle, most of the time when I am not using it, it will BSOD with the error code 0x101, which I know means insufficient voltage to the CPU but, it's perfectly fine when at 100% cpu usage, it's stable as a rock. I have all power saving features turned off. I can't figure out the problem on my own.
Can anybody help?
EDIT : Ignore my signature, the CPU is currently at 4.5, just to make sure it's not insufficient voltage.
Can anybody help?
