Hi guys,
I put another 16GB (2x8GB) of Corsair CMK16GX4M2B3000C15 in my machine about 2 moths ago, and ever since I have had random BSODs with varying messages. I have never had one in the previous 3 years with my machine,, pointing to to be the new sticks of RAM. I ran memtest86 yesterday and it shows 39 errors. In the results HTML file here are the last 10 errors
2018-12-22 12:25:05 - [Data Error] Test: 8, CPU: 2, Address: 7E0E36F80, Expected: 910E653C, Actual: 110E653C
2018-12-22 12:24:52 - [Data Error] Test: 8, CPU: 2, Address: 771C36340, Expected: A0461925, Actual: 20461925
2018-12-22 12:24:21 - [Data Error] Test: 8, CPU: 6, Address: 69BB83080, Expected: 86D9D7AA, Actual: 06D9D7AA
2018-12-22 12:23:36 - [Data Error] Test: 8, CPU: 2, Address: 5326E2C80, Expected: AFC36692, Actual: 2FC36692
2018-12-22 12:23:28 - [Data Error] Test: 8, CPU: 2, Address: 4F3B3E040, Expected: 78B32A47, Actual: F8B32A47
2018-12-22 12:23:18 - [Data Error] Test: 8, CPU: 4, Address: 4B5E14E40, Expected: D9A5429B, Actual: 59A5429B
2018-12-22 12:23:00 - [Data Error] Test: 8, CPU: 6, Address: 4280E0D80, Expected: 926D9A01, Actual: 126D9A01
2018-12-22 12:22:58 - [Data Error] Test: 8, CPU: 4, Address: 414E1E0C0, Expected: 4515EDDE, Actual: C515EDDE
2018-12-22 12:22:35 - [Data Error] Test: 8, CPU: 4, Address: 3658992C0, Expected: 4DD008EB, Actual: CDD008EB
2018-12-22 12:22:26 - [Data Error] Test: 8, CPU: 2, Address: 322928540, Expected: BB3D1219, Actual: 3B3D1219
and here is the overall result,
Test # Tests Passed Errors
Test 0 [Address test, walking ones, 1 CPU] 4/4 (100%) 0
Test 1 [Address test, own address, 1 CPU] 4/4 (100%) 0
Test 2 [Address test, own address] 4/4 (100%) 0
Test 3 [Moving inversions, ones & zeroes] 4/4 (100%) 0
Test 4 [Moving inversions, 8-bit pattern] 4/4 (100%) 0
Test 5 [Moving inversions, random pattern] 4/4 (100%) 0
Test 6 [Block move, 64-byte blocks] 4/4 (100%) 0
Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
Test 8 [Random number sequence] 0/4 (0%) 39
Test 9 [Modulo 20, ones & zeros] 4/4 (100%) 0
Test 10 [Bit fade test, 2 patterns, 1 CPU] 4/4 (100%) 0
Test 13 [Hammer test] 4/4 (100%) 0
As you can see they are all in the 'random number sequence'. Should I run the test again abut remove the latest 2 sticks of RAM? Or can you see from the results that they are broke?
Thanks
Thanks
