Permabanned
- 3 Jul 2008
- My fabulous ship
Ok guys I am at the end of my tether now. Please enjoy the frustration I have to endure.
before you read - sorry if you struggle to read this. at least the spelling is fine
We thought this worked as my house mate stayed home during the day to get to the engineer, what we didn't realise was that this was during the day not at peak time. the result when the engineer left and everyone came home, the same issue resumed. even on ethernet. so we decided to do the following:
check on 4 different routers (2 bt -v1.5 and 2.0 or what ever) 2 netgear routers
tried 4 different filters
every channel on the router for wireless (even though we also tried ethernet)
all this did nothing. sooooo....
what kind of ******* joke is this? Am I so stupid to have missed something blatantly obvious with this internet at my home? or is it BT? I checked the exchange at plusnet and they gave the exchange a green light for capacity so it's not because there's too many on the exchange. We are supposed to be getting 21cn by the end of the month and I can't even get past 125Kbps. it's a bad joke getting worse!
I am taking Friday off to sit by the engineer and drink my tea and eat double chocolate biscuits in my tea in front of him. With the heating off and the doors wide open. Once he's done I'm doing my speed test with him sat there freezing.
What do I do if it's still the same? If he says "I can get good speeds no problem!" should I say "well I tell you what, you take my router and use it in future for testing, and I will take your line checker and use it as my router." ?
- I first ordered BT back in July 8th. The order failed and had to reorder on the 21st.
- August 1st Telephone line Activates with no problems
- August 8th the re-ordered broadband activates with a speed of 126Kbps
- Phoned BT they said they can't do anything until line checks are completed
- 10 days pass, each test I did via bt.speedtester.com/speedtest.net gave 120-300kbps
- on the 19th (10 days of line checks) I phoned up and complained, they tell me the line is fine to which I had to educate the lvl 1 tech support the difference between connection rate, download speed, and a ip profile... Then had to do the same with his manager. They arrange an engineer to come out on the 22nd
- engineer comes out on 22nd and says there is no fault on the line and to try changing the channel on the router.
- Phoned bt and they arranged another engineer to come out on the 28th
- on 28th engineer comes - still can't find a problem, he goes up and down the straight checking for electrical interference and couldn't find anything
- bt phones up and tries palming me off again saying my line speed is fine blah blah blah and I tell them 128Kbps down is not fine at all. So they forward to BT Wholesale
- engineer comes out says no faults found and the tech support tells me they are sending me another router....
- last week the router came. And it did nothing. and bt's answer?
- "We need to send another engineer to the exchange to test!"
- engineer comes 2 days later, checks exchange, nothing found.
- get a call back saying the engineer found a fault and corrected it even though they said the engineer found nothing (female tech support for some reason is always worse than male tech support.) to which again I had to explain what the terminology was for and why she was wrong.
- final result? booked an engineer for a house visit on Friday.
