In the router settings it says:
Max download rate: 21265 kbs
Rate: 6652 kbs
IP Profile: 5500 kps
6652 kbs is what BT said our Router synced to, so that is the fastest speed we can get. But we used to have 15mb
But what i do not understand is, why not 21265 kbs or around it?
We had some BT Engineers round who found a fault and they said that we should easily be able to get 20mb as the cable length from us to the exchange is 740m.
Anyone know why we may not be able to get a decent speed?
Current DSL Connection:
Down / Up
Rate: 6652 kbs / 1168 kbs
Max Rate: 21321 kbs / 1184 kbs
Noise Margin: 28.4 dB / 6.4 dB
Attenuation: 17.9 dB / 6.9 dB
Output Power: 18.4 dBm / 11.9 dBm
Protocol: G.DMT2+ Annex A
Channel: Fast
ATM PVC: 0/38
Rate Cap: 21321 kbs
Attenuation @ 300kHz: 17.9 dB
Uncanceled Echo: -16.4 dB Ok
VCXO Frequency Offset: 4.4 ppm Ok
Final Receive Gain: -1.3 dB Ok
Impulse Noise Comp. Tones: 0 Ok
Excessive Impulse Noise: 0 Ok
Cheers (Going rather mad talking to BT!)
Rate: 6652 kbs
Down / Up
Channel: Fast
ATM PVC: 0/38
Rate Cap: 21321 kbs
